Stay informed. Get help. Share your knowledge.
17347members
301722posts
Explore
Hot topics
Cannot select editable elements in 3D window
Hi, I'm having an issue in Archicad 24. I have drawn new elements which are editable in plan view (reserved, unlocked, layer unlocked etc) but when viewed in the 3D window I am only able to select a few of these elements. When I click on certain wall...
Archicad deploiement / Silent install
Hello, From Archicad 22 it's possible to deploy Archicad and its updates silently. The command for macOS is : Archicad 22/Installer.app/Contents/MacOS/installbuilder.sh --mode unattendedThe installbuilder.sh script has not been adapted. It only takes...
Object's surface painter override bug
Hi All,Have any of you experienced or be able to replicate this bug?:Use objects - say a windowUse the Surface painter and override the frame surface.Then go and change anything... something not relevant, like the IDBUG shows up: Surface override get...
Viewer Stories
Inside of stories settings it doesnt appear the model display for apply uniform surfaces to the CUT ELEMENT in general, besides this settings still appears at the section settings and elevations. Settings at sections settingsI hope i will recived a s...
Ac 22 MEP modeler license
Hello everybody.It is possible to have a MEP modeler license from earlier versions.I need an Ac 22 MEP modeler license.Is Graphisoft still selling or marketing them?Thanks
Levlark by Participant
  • 55 Views
  • 3 replies
  • 0 likes
Announcements
Building Together digital event - watch the recordings!
GRAPHISOFT's Building Together 2021 conference for the AEC community took place in the virtual space last week. We invite you to watch the recordings of the keynotes, trend talks, testimonials, and roundtable discussions with leading architects, engineers, and scientists from all around the globe.
Topics addressed the most challenging issues architects and engineers face today, such as affordable housing, urban planning, landmark preservation, and the most exciting challenges in algorithmic design, digital transformation, and many more.
You can still register, and log in to watch the recordings anytime.
Enjoy the content!
