It would be super nice if......Here is the setup:You are looking at a Layout with DrawingsYou have the Element Information Palette visibleYou click on a Drawing on the LayoutElement Information Palette Displays:The Drawings full View ID and NameIf th...
I'm trying to create a model to export to Twinmotion. Twinmotion applies materials to like materials (i.e. anything you say is Glass Type 1, gets the same material applied to it. For some reason the door I'm using is not rendering out the glass as gl...
what is this symbol that just popped up in my Archicad. what key did i hit to bring it up and what key to get rid of it it seems to do nothing . if it is hard to see in teh pdf its a circle with a triangle in it and cross hairs Long time user since v...
I typically have 5 or more instances of AC open. I have never needed Cineware or tried to use it. When I look at my Mac's memory usage each open instance is using a lot of memory for Cineware. Is there away to turn it off? Thanks
Hi, has anyone had any luck getting correct outputs with the Cel Shader in AC23? I've wrestled with it a few times, but can't seem to get it to behave as I'd expect. I've been following a few Cinema4D tutorials (as I believe that's what it's based on...
Why doesn't text/autotext have this?Maybe where is this?
Hello, I'm creating a object which reads a text file that another object writes to. I've got the workflow working as intended however I am required to manually update the object which reads from the text file. Both are placed on separate layouts. Is ...
It would be great if the interface were updated so that when a section, elevation or detail marker is selected and 'Views from this [marker]..' from the right-click context menu is selected that ONLY the relevant views are displayed rather than the e...
We're working on Archicad add-ons at my company and would like to onboard a part-time C++ developer to our team. Let me know if you have any recommendations or you know online communities where I can contact them.
Hi, I've recently come across a weird issue. I want to placed an object from the standard Archicad library but it it greyed out from the Obejct Default Settings windows. Here's an screen shot. I can navigate through the folders but I can't choose the...
Explore our full product portfolio update at the Graphisoft release event on Thursday, July 14.
Read details and register for free today here.
We are excited to announce a new Community Challenge! This time we invite you to share your cool experiments with Graphic Overrides by sending us a GIF with a before and after of your project.
You can find more details and further instructions here.
If you want to improve your knowledge and develop your skills in Archicad, BIMx and BIMcloud, Graphisoft Learn has some new courses and learning paths.
Learn more details here.
Some of our Snow Globe Challenge participants collaborated with us to publish a few articles about their workflows and tips.
All 5 articles of this series are available now in our Design category.
Check out a short summary of each here.
