Stay informed. Get help. Share your knowledge.
17640members
301898posts
Explore
Hot topics
Dynamic Array/Sequence tool
Construction elements are very often spatial configured in arrays with the implication that the individual elements shouldn't be regarded as mere copies without any other relationship but as members of a clearly defined system. Columns and beams, raf...
thesleepofreason_1-1632431016931.png thesleepofreason_2-1632431086395.png thesleepofreason_0-1632432064875.png thesleepofreason_5-1632433553706.png
Add-on <-> GSM : communication
HiCan an Archicad add-on and a GSM object communicate with each other? I simply need the GSM to check the state of a variable in the (C++) add-on, and vice-versa.Thanks.
Beam Reference Lines do not show in Archicad 24
I've noticed that in Archicad 24 beam reference lines do not show upon element selection like wall reference lines do. I have to show the beam axis lines for it to show. In previous versions it used to show upon selection regardless of whether Axis L...
Cinerender Surfaces Problem
I'm running AC25 (3011) and have noticed a glitch with the Cineware Surfaces dialogue boxes. All of the preview images for Noise are black! The previous iteration of AC25 was fine. FYI, I have upgraded to Big Sur 11.6 which may be part of the problem...
Importing Microstation 3d files
I am having difficulty importing a Microstation fileCould not find a way to import directly into the Archicad file And tried to open the 3d Mstation file and it opened a 2d document I can only see in the floor plan
Teamwork - Queue commands
It would really help if it was possible to queue up teamwork commands, such that once conditions that were preventing a teamwork operation resolve, a queued command such as send and receive, or release all, automatically occur straight away. Right no...
Announcements
Building Together digital event - watch the recordings!
GRAPHISOFT's Building Together 2021 conference for the AEC community took place in the virtual space last week. We invite you to watch the recordings of the keynotes, trend talks, testimonials, and roundtable discussions with leading architects, engineers, and scientists from all around the globe.
Topics addressed the most challenging issues architects and engineers face today, such as affordable housing, urban planning, landmark preservation, and the most exciting challenges in algorithmic design, digital transformation, and many more.
You can still register, and log in to watch the recordings anytime.
Enjoy the content!
