Stay informed. Get help. Share your knowledge.
17033members
301427posts
Explore
Hot topics
Cad monitors v. Games monitor
Having ordered a new computer with an RTX graphic card I am also considering replacing my 10 year old Dell 27" monitor. with a new 32" 4K screen. Is there such a thing as a CAD monitor, or will any good 4K screen such a Dell, Samsung, LG or HP, etc.,...
KeesW by Participant
  • 1 Views
  • 0 replies
  • 0 likes
Archicad-Grasshopper Live Connection Problem
Hello, I'm having problems with setting up my Archicad-Grasshopper Live Connection. Once installed the menu item for the plug-in looks weird ("%%$GrassHopperConnection.STRS.32500.1%%") and is greyed out, as seen in the attached photo. Both Archicad 2...
splinter by Participant
  • 32 Views
  • 0 replies
  • 0 likes
Railing tool
I'm trying to create a custom railing and cant get rid of the end extensions and end cap, what am I doing wrong here?
SLAB DOES NOT SHOW IN SECTION
Archicad 20 THE SLAB WILL NOT SH0W IN SECTION BUT IF YOU CLICK ON WHERE IT IS SUPPOSED TO BE IT LIGHTS UP AND SHOWS THAT IT IS THERE. I TRIED ERASING IT TO MAKE SURE THERE WAS NOT TWO WITH EACH ONE HIDING THE OTHER. ALSO, I MADE SURE THAT IT WAS NOT ...
EXPODTL by Newcomer
  • 32 Views
  • 1 replies
  • 0 likes
Profile Beam Top and Bottom Elevation
Is there a way to get a readout of the bottom and top elevation of a selected profile beam? All I can find is the center, which requires math to find the bottom or the top.
R Muller by Participant
  • 25 Views
  • 0 replies
  • 0 likes
WHERE ARE MY ELEVATIONS? (PROJECT MAP)
I have my floor plans but I can't find my elevations. Though I have the Elevation uhmm word there, I can't find the north, south, east, and west elevations under that uhmm word. How can I fix this, pleas help.
Create a new Model View Options
Hi,In a custom Add-On i try to create a new custom Model View Options. Using the "ACAPI_Attribute_Get" i can get access the API_Attribute properties and in that properties i can get any specific Model View Options related properties. But when i try t...
Jahidur by Participant
  • 25 Views
  • 0 replies
  • 0 likes
Selection of hidden elements
Hello there!I have a little issue. When I select an element in the plan and in the elevation it selects even hidden element behind the element I need to select. For example, on plan, clicking on the slab it selects the beam underneath. And same issue...
stevini by Contributor
  • 36 Views
  • 3 replies
  • 0 likes
Roof rafter dimensions in Schedule of Elements
Could some please advise how do I get dimensions of a roof rafter, such as: (1) Profile Height (rafter height), (2) Profile Thickness (rafter width) and (2) Lumber Size (rafter length) in Schedule of Elements. The rafter is sourced from Archicad Libr...
Voytek by Participant
  • 28 Views
  • 1 replies
  • 0 likes
Announcements
Building Together digital event - watch the recordings!
GRAPHISOFT's Building Together 2021 conference for the AEC community took place in the virtual space last week. We invite you to watch the recordings of the keynotes, trend talks, testimonials, and roundtable discussions with leading architects, engineers, and scientists from all around the globe.
Topics addressed the most challenging issues architects and engineers face today, such as affordable housing, urban planning, landmark preservation, and the most exciting challenges in algorithmic design, digital transformation, and many more.
You can still register, and log in to watch the recordings anytime.
Enjoy the content!
Most liked authors
