Archicad AI Visualizer
The new AI Visualizer in Archicad 28 is now fully cloud-based, with more flexibility and advanced controls. It does not require technical expertise to set up or advanced hardware to run. Click here for more details.
This Community group is dedicated to the AI Visualizer for Archicad 27, powered by Stable Diffusion. The AI Visualizer is an experimental tool allowing you to create detailed 3D visuals in the early design stage. The Archicad 27 version is designed to run locally on your desktop without requiring an internet connection. It will reach End of Service on December 31, 2024. For more information, please click here.
Group Hub Activity
More
Group Hub Information
Say hello to Archicad AI Visualizer, our new experimental, AI-driven image generation tool. Powered by Stable Diffusion, you can create impressive, detailed 3D visuals in the early design stage without needing a complex model. In this group, you can explore the tool in depth, read technical documents, and share your visuals and questions with other users.
343 members
Open group
Created 2023-10-25
Want to get started?
Members (343)
