Removing Triangulation from Imported SketchUp, Cinema 4D and 3D Studio Objects
automata
SketchUp, Cinema 4D, and 3D Studio objects can provide users with additional content not found in the standard ARCHICAD libraries. When imported, these objects can contain unwanted contour lines noticeable in both 2D and 3D. Furthermore, the parametric customization of the object (specifically with regards to materials) is limited. The Morph tool provides a way to remove unwanted contours and change the parameters of an imported object. Follow the steps below to customize SketchUp, Cinema 4D and 3D Studio Max objects in ARCHICAD using the Morph tool.
Step 1: Create a Morph
Select the object, right click and choose Convert Selection to Morph(s).
Step 2: Change the Morph Settings
To clean up the morph by removing unwanted contour lines, select it and open the Morph Selection Settings dialogue box. Under the Model tab change Edges from Hard to Hidden. Click OK.
Only contour lines that are vital to defining the volume will remain. The 2D representation of the morph will reflect the simplification of the 3D volume.
Step 3: Changing Materials
To change the material of part or all of the morph click on one of the faces. From the Pet Palette select the Custom Face Settings option.
In the Custom Face Settings dialogue box, choose Face Material. For Texture setting select Planar. Finally, set Apply changes to All Similar Faces. This will change the texture of the selected face as well as all others that have the same material. To only change the texture of the selected face, choose Clicked Face. To change the texture of the entire morph select All Faces.
Step 4: Save the Morph as an Object
From the 2D plan view, select the Morph, go to File/Libraries and Objects/Save Selection as Library Part and choose Object. Click OK.
wp-content_uploads_2016_06_Info_18x18.png NOTE: Saving objects from plan view keeps the desired 2D representation intact. Objects saved from 3D views have 2D representations automatically derived from their 3D forms. In the Save Object dialogue box name the object and choose a location to save it. Click OK.
The window below will appear listing the available parameters of the object. Click OK.
wp-content_uploads_2016_06_Info_18x18.png NOTE: Morphs created from imported objects that are saved from a 3D view will not have parameters.
The edited object can now be placed using the Object Tool.
Browse more articles
Back to articles
