Add-on articles
Articles
Energy Evaluation - Troubleshooting Guide
Affected version: 22 | Severity: workaround applicable | ID: 258061 Note: This error is fixed in ARCHICAD 22 Update Build 6021. Issue At Design > Energy Evaluation > Operation Profiles the values of Human heat gain, Service hot water load and Humidit...
How to Use the Wood Ceiling Add-On
The Wood Ceiling add-on allows users to apply 3D wainscoting to an existing roof. Before Starting 1. Download and install the Goodies package here. 2. Add the Accessories Library to the project library. It is located under the ArchiCAD version folder...
How to Use the Roof Surfacer Add-On
The Roof Surfacer add-on allows users to apply 3D cladding to an existing roof. Before Starting 1. Download and install the Goodies package here. 2. Add the Accessories Library to the project library. It is located under the ArchiCAD version folder u...
Accessories Add-On
How to use Accessories Add-on With the help of this ARCHICAD Add-On you can supplement the roof, slab and wall elements with special objects. Make sure you add the Accessories Library to your project, using Library Manager. First, select an existing ...
ARCHICAD is unable to connect to Google Earth on Mac
Affected versions: All ARCHICAD versions - Mac only| Severity: To be fixed in the next update, workaround available Using the File/Interoperability/ Send Model to Google Earth command could result in the following error message: ARCHICAD is trying to...
Grasshopper - ARCHICAD Live connection: Teamwork
This article summarizes how ARCHICAD elements generated and modified by the Grasshopper - ARCHICAD Live connection behave in a Teamwork environment. Reservation Elements created in a Teamwork environment from Grasshopper will be locked and reserved b...
Intersections in Layer Combinations Add-On
In ARCHICAD 8 and subsequent versions, intersection cleanup is linked to the Intersection Group Numbers assigned to layers. Elements which belong to layers having the same Intersection Group Number will intersect, regardless of layer visibility. Elem...
Labels
Top Contributors
