Add-on articles
Articles
Mesh To Roof Add-On
INTRODUCTION Irregular "free-form" shapes can be modeled using the mesh tool. These items can be converted to roofs with this Add-On. The new "Create Roofs from Mesh" command will appear in the "Design/Design Extras" menu by default. HOW TO USE "Mesh...
RAL Color System Add-On
INTRODUCTION RAL Colour Standards are developed and controlled by the German Institute of Quality Assurance and Trademark Control. The 194 classical shades (RAL 840-HR) and the RAL Design System with its 1688 colors are both well known in a number of...
Profiler Add-On
Introduction The Profiler Add-On allows you to create Object type Library Parts by extruding a profile along a straight or curved path. The new Profiler command will appear in the Design/Design Extras sub-menu by default. How to use Profiler Add-On T...
Polygon Counting Tool Add-On (PolyCount)
INTRODUCTION PolyCount is an ARCHICAD add-on that helps you control the number of 3D polygons in your ARCHICAD models. This tool can be used effectively if the project size or the limited physical memory of your computer makes the 3D model size a cri...
Interior Wizard Add-On
INTRODUCTION The Interior Wizard command enhances the modeling of 3D Zones by applying Accessory Objects to selected walls, ceilings and floors and creating interior finish elements. You can edit the shape and the material parameters of these element...
Check Duplicates Add-On
INTRODUCTION This ARCHICAD Add-On can find, select or delete items sharing the same parameters (type, color, thickness, height, etc...) and occupying the same spot on the floor plan. Unwanted doubles are typically created by either accidentally doubl...
3DStudio In Add-On
Introduction This ARCHICAD Add-On can convert 3D Studio Max (.3ds) files to ARCHICAD as GDL objects. The conversion process can be customized by the user. Download and install "3DStudio In" Add-On You can download this Add-On amongst other Goodies by...
Construction Simulation Add-On
Introduction In previous versions, the set of commands will appear in the Document/Schedules and Lists/Construction Simulation submenu by default. Since AC20 you can find it under Document/Listing Extras/Construction Simulation. The commands of the C...
About Goodies
Goodies are free Add-Ons developed by GRAPHISOFT to complete ARCHICAD with specific abilities and features. As of ARCHICAD 22 you can install all Goodies at once with the help of the ARCHICAD Goodies Suite installer. Goodies are based on legacy code ...
Getting Started with the API DevKit
Creating custom add-ons for ARCHICAD requires a solid knowledge of C and C++ as well as a willingness to learn through studying sample code, documentation and header files. Be sure that you have read the "API White Paper" in the documentation to be s...
wp-content_uploads_archicadwiki_developer-getting-started-with-the-api-devkit--1_new_database.png wp-content_uploads_archicadwiki_developer-getting-started-with-the-api-devkit--2_authorization.png wp-content_uploads_archicadwiki_developer-getting-started-with-the-api-devkit--3_new_addon.png wp-content_uploads_archicadwiki_developer-getting-started-with-the-api-devkit--savedatabaseash.png
mtron by Graphisoft
  • 321 Views
  • 0 comments
  • 0 likes
Labels
Top Contributors
