Add-on articles
Articles
Polygon Counting Tool
The complexity of a plan, especially the 3D model mainly depends on how many polygons it contains. Polygons are the most basic 2 dimensional plain geometric elements that form the 3D model. Polygon Counting Tool is an ARCHICAD add-on that helps you c...
3D Studio Files in ARCHICAD
Import 3ds Max Files (.3ds) With the help of '3DStudio' In Add-On you will be able to convert .3ds files to ARCHICAD GDL objects. By default, it is not integrated into ARCHICAD. You can find a detailed description about the Add-on and how it works on...
mtron by Graphisoft
  • 920 Views
  • 0 comments
  • 0 likes
Grasshopper - ARCHICAD Live connection
The Grasshopper - ARCHICAD Live Connection Add-On enables users to create and manipulate full fledged BIM models through Grasshopper’s visual scripting interface to create geometries in ARCHICAD which weren't possible to create before and still retai...
Rhino - ARCHICAD connection Troubleshooting Guide
Known issues Texture Problem with imported Rhino files Affected version: 18, 19 & 20 | Severity: workaround applicable | ID: 206277 Issue No textures are displayed on Rhino Imported NURBS defined surfaces in ARCHICAD. Cause The textures are actually ...
Artlantis/Twinmotion Troubleshooting Guide
Known Issues Twinmotion export Add-on is not working without VCRedist 2013 on Windows Affected version: 20 | Severity: workaround applicable | ID: 211370 NOTE: We plan to fix this issue in an Upcoming ARCHICAD 20 Update. Issue The Twinmotion export A...
Labels
Top Contributors
