Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
AI Visualization "Torch is not able to use GPU"
Ingolf
I am not able to install the AI Visualizer on one PC (I7), but on another PC (also I7) the install works fine.
I have the Intel card connected to Archicad.
I run Archicad in Administrator mode.
Stange...
This is the message:
Python 3.10.6 (tags/v3.10.6:9c7b4bd, Aug 1 2022, 21:53:49) [MSC v.1932 64 bit (AMD64)]
Version: v1.6.0
Commit hash: 5ef669de080814067961f28357256e8fe27544f4
Traceback (most recent call last):
File "C:\sd.webui\webui\launch.py", line 48, in <module>
main()
File "C:\sd.webui\webui\launch.py", line 39, in main
prepare_environment()
File "C:\sd.webui\webui\modules\launch_utils.py", line 356, in prepare_environment
raise RuntimeError(
RuntimeError: Torch is not able to use GPU; add --skip-torch-cuda-test to COMMANDLINE_ARGS variable to disable this check
Press any key to continue . . .
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
5 REPLIES 5
Norbert Kucsma
Hi Ingolf,
Thanks for the question.
Please note that the AI Visualizer Add-on is compatible with NVIDIA GPUs only. The minimum system requirement is 8 GB of VRAM.
Kind regards,
Norbert Kucsma
Technical Support Engineer
i have amd rx 6800 with 16 GB Vram and have same problem.
The problem is not the amount of GPU VRAM. As Norbert mentioned, AI Visualizer Add-on is compatible with NVIDIA GPUs only. You have an AMD GPU.
where can i find AI Vizualizer Add-on for AMD GPU?
It is not available for AMD GPUs. Currently, it is available only for machines with Nvidia GPUs.
