Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
AI Visualizer - Windows
Ancha
I did the installation and copied the folders to the correct place (the sd.webui in C and the Add on to the Archicad folder).
But when starting Archicad 27 opening the AI Visualizer from the Palettes and clicking on Generate, I get this error about the AI server:
What is this and how to make it work normally?
Thank you in advance.
21 REPLIES 21
Rogerio M
Hi!
Unfortunately, I'm having the same issue and cannot get past it.
Windows 10 Pro, Intel i7-9700 3.0GHz, 32Gb, RTX 2060
Archicad 27 BRA 5003
Me too...same problem
Wayne T
I tried everything and eventually got mine to work.
Below are the three changes I made that worked for me.
I changed the AI Engine address to 127.0.0.1:7860
I ran the runHighVram file as an administrator ( in the sd.webui folder)
Finally, I disabled my Intel graphics card in my device manager.
That worked for me, I hope it helps you.
Thats not working for me.
This probably works for NVIDIA graphic cards only. Doesnt work on Radeon or Intel
Is this really the case?
Is there any way to specify the GPU - there must be a setting somewhere (instead of disabling the Intel-onboard card).
Or???
Erik Bjornhage : SwedishChef, ETTELVA Arkitekter, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
ETTELVA Arkitekter : Eriks LinkedIn
DELL Precision 5570; i7-12700H; 64 GB; RTX A2000 [8GB] : AC12 - future
Like I said that worked for me.
Have you tried running Archicad as administrator?
I did run it as admin and nothing changed. The same error pops up when clicking on Generate.
I also clicked "Start AI Engine" and this is the window that opens:
What should be done?
