Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
AI isn't generating image - "The generation process has ran onto an error'
Raymon Lopes
I don't know what I did wrong or what to do, not quite understand the usage of the terminal and how it works but I followed the instructions of installation correctly by far. Attached the terminal before and after trying to generate. Please HELP.Captura de Tela 2024-01-18 às 12.14.38.pngCaptura de Tela 2024-01-18 às 12.30.40.pngCaptura de Tela 2024-01-18 às 12.31.58.pngCaptura de Tela 2024-01-18 às 12.32.06.pngCaptura de Tela 2024-01-18 às 12.32.13.pngCaptura de Tela 2024-01-18 às 12.32.16.pngCaptura de Tela 2024-01-18 às 12.32.20.png
3 REPLIES 3
Norbert Kucsma
Hi Raymon,
Thanks for the screenshots.
Your device runs out of memory while generating a picture. Please try to start the engine in low VRAM mode.
On the AI Visulaizer UI:
  • stop the engine (the button next to the 'Start AI Engine') and wait a minute
  • uncheck the 'Start in High Vram mode' checkbox
  • Start the AI Engine (and wait for it to start)
  • generate a picture
Kind regards,
Norbert Kucsma
Technical Support Engineer
Angus J
Hi Norbert,
I am also having the same problem, but low vram mode doesnt seem to fix it.
Please see attached error
Screenshot 2024-02-12 at 3.14.19 pm.pngScreenshot 2024-02-12 at 3.13.45 pm.pngScreenshot 2024-02-12 at 3.13.24 pm.pnginfo.
Kind Regards
Hi Angus J,
Thanks for the details.
It looks like the process is slow and after 10 minutes of generation, it fails. However, 16 GB should be enough in low VRAM, please try again after closing any other running apps in the background. Even after a restart, you can try to start Archicad and generate a picture.
I hope it will work.
Kind regards,
Norbert Kucsma
