Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
Ai Server not available
Michiel Neven
I, Have Downloaded the AI Virtualizer, dragged it in to the add-onn folder but receive an AI server not available Error. What am i doing wrong?
25 REPLIES 25
mbeckmann
There are a lot of other steps, make sure you do all of them in order. https://assets.graphisoft.com/guides/AI_Visualizer/AI_Visualizer-Installation_Guide.pdf
lopezfigueroa
sd.webui=   C:\sd.webui
AI Visualizer= C:\Program Files\GRAPHISOFT\Archicad 27INT\Add-Ons
A1zet
Have you resolved this issue? I have the same problem, only on windows(
3D projektant
Hi, a have the same problem on my windows. Does anyone know how to solve this? 😉
Guillermo1
Is Only for INT version?
goncalovalente
Hi, a have the same problem on my MAC.
Michiel Neven
Thank you all, Following al the steps as suggested did the trick. Not sure how to solve it on a WIN computer. I Work with the NED version and it works fine after the correct installation steps!
Use the therminal on mac to follow the correct installation procces.
Me too
is it working perfectly fine for you on windows?
