Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
Visualiser not running -> ERROR: No matching distribution found for torchsde==0.2.5
MBu_pg1
After installing, throw the "AI_Visualizer-Installation_Guide"
i have an issue after running "run.sh"
The Command stops with the Prompt:
Please use pip<24.1 if you need to use this version.
ERROR: Could not find a version that satisfies the requirement torchsde==0.2.5 (from versions: 0.2.5, 0.2.6)
Has someone a workaround for this?
34 REPLIES 34
Cristiano
I have the same issue
peterfat
same problem
Carinoa Campos
Hello, I have the same problem!
dsalgadom
Same thing here, did you find a solution?
Monsieur_405
I have exactly the same problem. If you edit the 'version requirements' .txt file so the script looks for torchsde 0.2.6 instead, you just run into a different error:
from pkg_resources import packaging
ImportError: cannot import name 'packaging' from 'pkg_resources' (/opt/homebrew/lib/python3.10/site-packages/pkg_resources/__init__.py)
It would be fair to say that AI Visualizer is bricked software until this issue can be resolved.
Norbert Kucsma
Hi all,
We apologize for the delay and any inconvenience this may have caused. Unfortunately, the current macOS installer for AI Visualizer is not functioning properly. Our developers are actively working on a solution.
If installing the AI Visualizer is critical for your business, please reach out to your local technical support for assistance.
We appreciate your understanding and patience as we work to resolve this issue.
Kind regards,
Norbert Kucsma
Technical Support Engineer
dsalgadom
Thanks for your answer Norbet!!! How we would be notice when it would be fixed? Cheers
Hi Norbert!
Any update on this subject ?
Hi Piotrihnat,
Thank you for your patience. We're actively working on a solution, and we hope to have the install package fixed in the coming weeks.
Sorry for the inconvenience.
Kind regards,
Norbert Kucsma
