Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
Visualiser not running -> ERROR: No matching distribution found for torchsde==0.2.5
MBu_pg1
After installing, throw the "AI_Visualizer-Installation_Guide"
i have an issue after running "run.sh"
The Command stops with the Prompt:
Please use pip<24.1 if you need to use this version.
ERROR: Could not find a version that satisfies the requirement torchsde==0.2.5 (from versions: 0.2.5, 0.2.6)
Has someone a workaround for this?
32 REPLIES 32
I have the same issue, previously. I think the link is just general web for AI Visualizer. Now, I can found the new package in this LINK.
DeMoyerArch
Same torchsde Error here too.
Can we expect this issue to be rectified with the release of AC28?
Also, I'm being prompted to move from 'bash' to 'zsh', will AI Viz still work on 'zsh' ?
