Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
When hit Generate - AI Visualizer get message - Image generation failed - no server
Kiro
No connection to the Server.
Message when begin AI generation.
I put IP address: 127.0.0.1:7860
The screen shot is in the attachment.
Thanks in advance for your help to sort out this problem.
1 REPLY 1
Norbert Kucsma
Hi Kiro,
Thanks for the question.
I suspect that the engine is not running. Please click on the Start AI Engine (and wait for it to start) then try to generate an image.
In case it still fails, please contact your local support and share the Command Prompt window output as well.
Kind regards,
Norbert Kucsma
Technical Support Engineer
