2023-12-15 04:35 PM - last edited on 2023-12-19 04:01 AM by Laszlo Nagy
hi, I installed AI visualizer plugin on AC 27, installed on terminal everything in accomplice with instructions, and everything works properly, I get the renderings and I'm learning to refine the prompt technique and optimize the interface parameters.
However, I noticed in the terminal window that opens when I press the "generate" button that during the process appears a message like:
"no module 'xformers'. Processing without...
No module 'xformers'. Proceeding without it."
Is this normal? I tried installing cuda, then torch and finally xformers... but the message keeps appearing. How can I solve and optimize the process for my machine? I use a Mac Studio with M1 MAX processor and 64 GB of RAM.
thank U for your suggestions
2023-12-28 11:46 AM
Hi Amati,
Thanks for the question.
Don't worry, this is the intended workflow and the normal behavior.
Have a happy New Year!
Kind regards,
Technical Support Engineer
