Archicad C++ API
SOLVED!
[API] how to set "element.column.linkToSettings.homeStoryDifference"
Boling1
Hi,guys
I can create column,but don't know how to cennect to uper story?
GSErrCode err = ACAPI_Element_GetDefaults(&element, &memo);  //setting: column connect to upper story but //don't work
element.column.axisRotationAngle = 0;
point.x = 0;
point.y = 1;
element.column.origoPos = point;
//Use this structure during element creation. If it is true, then head.floorInd will not be taken into account, //otherwise homeStoryDifference will be filled.
element.column.linkToSettings.newCreationMode = false;
 element.column.linkToSettings.homeStoryDifference = ?????;
element.column.head.floorInd = ???;
err = ACAPI_Element_Create(&element, &memo);
how to set "head.floorInd" or "homeStoryDifference"
ArchiCAD 25
1 ACCEPTED SOLUTION
Solution
poco2013
Mentor
To Link to upper stories:
element.column.relativeTopStory = (short)  where 0 = not linked # = stories above
column segments will be proportional to height if set as such. Also set "show on relative stories"
offsets are both in element and memo.
Unless your asking something else??
Gerry
Windows 11 - Visual Studio 2022; ArchiCAD 27
1 REPLY 1
Solution
poco2013
Mentor
Gerry
