Le Tan Kien
Archicad API – Create Master Layouts and place 2D/AutoText vs. Drawings
Body:
  • Environment: Archicad version V28, Windows
  • Goal: From a C++ add-on I want to (1) create a Master Layout, (2) place 2D content (GDL title block, Text/AutoText, lines) on the Master, and (3) create Layouts that use this Master. Drawings (viewports) should be placed on the Layouts, not the Master.
  • Questions:
    1. API entry points to create a Master Layout and set its page size/name?
    2. How to open the Master’s drawing database and create 2D elements / place a GDL object / insert AutoText there?
    3. How to create a Layout and assign the Master Layout by ID?
    4. Confirm: Drawings (View references) cannot/should not be placed on Master Layouts—only on Layouts, correct?
    5. Any minimal code snippet or docs pointers for the above steps?
  • Attachments: screenshot of my Masters panel and target layout result.
0 Replies 0
