2024-06-11 04:19 AM
I am trying to set up the CMake environment for AC27 example projects
I have followed the web example of how to set up the CMake environment, but without success:
Clone the repo with
git clone (message won't allow me to insert html) --recurse-submodules
Run the build script
python Tools/BuildAddOn.py --configFile config.json --acVersion 26 27
I get the following output:
Downloading API.Development.Kit.WIN.26.7000.zip
Extracting API.Development.Kit.WIN.26.7000.zip
Downloading API.Development.Kit.WIN.27.3001.zip
Extracting API.Development.Kit.WIN.27.3001.zip
[WinError 2] The system cannot find the file specified
This indicates that I have downloaded the repo fine, because it finds the tools folder and the Python script. The problem is I have no idea what "the file specified" is, because there is no log file. Running the script in verbose mode gives me this:
import 'tarfile' # <_frozen_importlib_external.SourceFileLoader object at 0x000001BB2FD06D50>
Can anyone help with getting the example projects set up?
Solved! Go to Solution.
2024-06-19 12:50 AM
Hi, Chris has helped me with this issue and it is now resolved. The problem was I didn't have a path to CMake.exe
2024-06-11 05:02 AM
Have you ever add your python to the path in enviroment variables.
2024-06-11 05:11 AM
Hi, yes I have.
2024-06-18 10:21 AM
Hi, Could you login from Archicad API site and download Devkit from web?
2024-06-19 12:50 AM
