leilei
ChamferPolygon2DDataContour and ChamferPolygon2DDataVertex can not get chamfer polygon
Hello! I get a zone Polygon2DData,when I test the ChamferPolygon2DDataContour and ChamferPolygon2DDataVertex with chamfered the zone polygon,the return err=NoError,But the resulting polygon is always zero count,Has anyone used these functions?
Test code below this:
static GSErrCode	ChamferPolygonWithRadius(Geometry::Polygon2DData& polygon2DData, vector<double> dRadius)
	GSErrCode err = NoError;
	////1.ChamferPolygon2DDataContour test
	//GS::VAArray<Geometry::Polygon2DData> chamPolys;
	//err = ChamferPolygon2DDataContour(polygon2DData, 1, 1.5, &chamPolys);
	//WriteReport_Alert("count is%d", chamPolys.GetItemCount());
	//WriteReport_Alert("err=%d", err);
	//if (err == NoError && chamPolys.GetItemCount() == 1)
	//	Geometry::CopyPolygon2DData(&polygon2DData, chamPolys[1]);
	//for (UIndex iResPoly = 1; iResPoly <= chamPolys.GetItemCount(); iResPoly++)
	//	Geometry::FreePolygon2DData(&chamPolys[iResPoly]);
	//2.ChamferPolygon2DDataVertex test
	Int32 minIndex = std::min(Int32(dRadius.size()), Int32(polygon2DData.nVertices));
	WriteReport_Alert("maxindex%d", minIndex);
	Int32 nvIndex = 0;
	for (Int32 i = 0; i < minIndex; i++)
		if (IS_ZERO(dRadius))
			continue;
		err = ChamferPolygon2DDataVertex(polygon2DData, i+1, dRadius, &chamPolys);
	return err;
1 Reply 1
leilei
Maybe I found the problem.When I use this polygon data with clockwise, it always gets the resulting polygon null,but err=NoError.
Now I have no problem when changing polygon data to counterclockwise. I can get the resulting polygon
success.
