Change Value of singleEnumVariant
Hi all,
I'm trying to change individual properties in Archicad. This is no problem with text fields, but I fail with SingleEmu.
prop is my API_Property Object and chaning value with singlevariant works flawless just by changing uniStringValue
					GS::Array<API_SingleEnumerationVariant> listOfEnum = prop.definition.possibleEnumValues;
					for (UInt32 i = 0; i < listOfEnum.GetSize(); ++i) {
						API_SingleEnumerationVariant enumerator = listOfEnum;
						auto name_of_value = enumerator.displayVariant.uniStringValue.ToCStr();
						API_Guid guid_of_value = enumerator.keyVariant.guidValue;
						std::string test4 = name_of_value;
						if (test4 == "Teppich") {
							prop.value.singleEnumVariant = enumerator;
			error = ACAPI_Element_SetProperty(Guid, prop);
My naive idea is to rite through the possible enumerators here and as soon as I have found the suitable one (here the entry "Teppich") and then attach this singleEnumVariant to my property I write back
But its not working and i dont get any error code either. Any Ideas?
Best Regards
Patrick
1 Solution
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Patrick,
I think you forgot to set the isDefault flag in the property object to false. If it remains true, than it does not matter how do you change the object because finally the element will still have the default value of the property.
if (prop.definition.collectionType == API_PropertySingleChoiceEnumerationCollectionType &&
	prop.definition.valueType == API_PropertyStringValueType)
	for (const API_SingleEnumerationVariant& enumValue : prop.definition.possibleEnumValues) {
		if (enumValue.displayVariant.uniStringValue == "Teppich") {
			prop.value.singleEnumVariant = enumValue;
			prop.isDefault = false;
			break;
Regards,
Tibor
Go to post
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi Patrick,
			break;
Regards,
Tibor
Thank you very much
