yahavsa
Change label's text to an autotext
Hi there
I'm trying to change a label's text to an autotext, which depends on it's parent type in this case. I got the key and value of the autotext that I need. Now I'm trying to insert the autotext into the label text, but haven't succeeded yet.
I'll really appreciated any solution.
Thanks!
4 Replies 4
poco2013
Mentor
From the API Documentation ----
"...an associative Label cannot be made independent, and an independent Label cannot be made associative."
Gerry
yahavsa
Hi Gerry
Thank you very much for the really fast response!
I'm not sure that I clearly understood that... in both cases, if I create an associative label or an independent one, I didn't succeed in placing an autotext in the text field instead of the default text that creates when I create a new label. I didn't try to make an existing associative Label independent, or make an existing independent Label associative.
Thanks again!
Windows 11, Visual Studio 2019, ArchiCAD 26
poco2013
Mentor
I understand that you are trying to change a autotext attribute to a different autotext attributive for the same  element? But you did not say of what type script are you using. If C++, you must use the proper autotext key format i.e with <> enclosure and format of <PROPERTY_ (GUID).
Gerry
yahavsa
Hello Gerry
That's right, I forgot to mention that I'm using C++, sorry about that.
I did try to use the proper autotext key format and I got an exception.
I'll go throw the process I did so maybe you can find something I did wrong:
- First of all, I created a default label element and change it's parent to a given window GUID (See attached TestLabelAutotext picture), Then:
1. First, I tried to use the relevant key given by the Hash table that I get when using the APIAny_GetPropertyAutoTextKeyTableID function.
It gives the format of PROPERTY_ (GUID) without the <> enclosure so I added it manually. When doing that, I get the exception (see picture Test1).
2. I tried to add the format of PROPERTY_ (GUID) manually, and I got the same exaption (See picture Test2)
3. I tried to change the format of PROPERTY_ (GUID) without using the <> enclosure. The label's text was changed, not to the autotext I need but to the format of PROPERTY_ (GUID) itself (See picture Test3)
