Archicad C++ API
Changing Drawing Title Object Parameters
Hi all,
I am looking to use the API to change custom parameters in a custom title object attached to a drawing, placed on a layout.
Documentation suggests API_DrawingTitle contains the GUID of the placed title element (the placed object), but if I use ACAPI_Element_Get with the GUID from element.drawing.title.guid I get an APIERR_BADID error. Is it possible to modify the custom GDL title object parameters of a placed drawing with custom title?
I have the layout already open and active when testing this, so the database should already be correct.
Thanks,
Danny
Akos Somorjai
Hi Danny,
You should be able to modify the title's parameters via the original drawing element's memo (specifically the `params` member should contain those values).
Best, Akos
Akos Somorjai
Hi Danny,
Best, Akos
Hi Akos,
Thanks - that works for what I need. So we cant use ACAPI_LibraryPart_ChangeAParameter and associated functions? I receive errors no matter what I set paramOwner.type.typeID to.
Kind regards,
Danny
Hi Danny,
The drawing title is tightly coupled with the drawing itself, so it cannot be handled separately.
Best, Akos
