Learn more
dushyant
Convert from GS::UniString to std::string
Hi
How to convert from GS::UniString to std::string?
(I need to pass it to another API which takes std::string)
Thanks.
3 Replies 3
Viktor Kovacs
To convert between GS::UniString and std::wstring:
GS::UniString ToUniString (const std::wstring& str)
	static_assert (sizeof (GS::UniChar::Layout) == sizeof (wchar_t), "string character size mismatch");
	return GS::UniString ((const GS::UniChar::Layout*) str.c_str (), (GS::USize) str.size ());
std::wstring ToWString (const GS::UniString& str)
	return std::wstring ((const wchar_t*) str.ToUStr ().Get (), str.GetLength ());
To convert between std::string and std::wstring:
std::wstring StringToWString (const std::string& str)
	std::wstring_convert<std::codecvt_utf8<wchar_t>, wchar_t> convert;
	return std::wstring (convert.from_bytes (str));
std::string WStringToString (const std::wstring& str)
	return std::string (convert.to_bytes (str));
dushyant
Hi Viktor,
Thanks for that info.
I found that simply doing:  std::string myStdStr(myUniStr.ToCStr())  works.
drjustice
(removed because redundant suggestion)
