Miha Nahtigal
Create and change database to newly created db
When I try to switch current database to newly created worksheet, I get APIERR_BADDATABASE (The command cannot be executed on the current database). The worksheet is sucessfully created but changing database fails. What am I doing wrong here??
	GSErrCode					err;
	API_DatabaseInfo			dbInfo;
	BNZeroMemory (&dbInfo, sizeof (API_DatabaseInfo));
	dbInfo.typeID = APIWind_WorksheetID;
	CHANSI2Unicode ("Det 1", (GS::Int32)strlen("Det 1"), dbInfo.name, API_UniLongNameLen);
	CHANSI2Unicode ("D10", (GS::Int32)strlen("D10"), dbInfo.ref, API_UniLongNameLen);
	if (ACAPI_Database (APIDb_NewDatabaseID, &dbInfo, NULL) == NoError) {
		err = ACAPI_Database (APIDb_ChangeCurrentDatabaseID, &dbInfo, NULL);
BIMquants - Free Plugin for Quantities and Costs Estimation in Archicad | BIMrender - Free & Open Source Plugin for AI rendering in Archicad
3 Replies 3
Oleg
You need to open the window this database after creation, before the database using.
( I dont check it in last APIs, may be it changed ).
ACAPI_Automate( APIDo_ChangeWindowID, &m_db, NULL );
Miha Nahtigal
Works! Thanks Oleg.
Akos Somorjai
This can be simplified to:
	GS::ucscpy (dbInfo.name, L("Det 1"));
	GS::ucscpy (dbInfo.ref, L("D10"));
Best, Ákos
