Archicad C++ API
Developing with the Educational License
Is this possible?
I have the required ID's, i just cant seem to create a new ADDON. The box is gray'd out
Help would be greatly appreciated
6 REPLIES 6
TomWaltz
What program are you trying to create the add-on with? What box is grayed out?
Tom Waltz
Archicad and its the create Addon Box, in the addon manager
TomWaltz
To create new add-ons, you need Microsoft Visual C++ 2003 or Apple XCode. There's no way to make new add-ons from within Archicad.
Tom Waltz
Once you have your own ID, you can run the AddOnAdmin tool to generate an add-on ID and also get the decimal equivalent of your four-character Developer ID. For Windows users, the AddOnAdmin tool is by default in
Program Files\Graphisoft\API Development Kit 5\Support\Tools\Win\AddOn Management
Click Create a New Addon to generate a new ID. Select the first line of the database tree (shows your Dev ID), click Save Database As, and choose *.h as the file type. Personally I don't use the names in that file, but grab the numbers.
I cannot click the create a new Addon button to generate a new ID. Therefore as i see it i will not be able to get AC to acknowledge my Addon written in C++.
You're talking about the devkit AddOnAdmin tool, which then calls itself Add-On Management.
To enable the 'new addon' button, you must have an open database that contains your authorized developer id. If you have already created such a database, just click Open Database to open it, then click the 'new addon' button. Otherwise, click 'new database' and fill in your Developer ID as a four character code.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thank you Karl, I am stupid
