Does not work ACAPI_Element_Change, API_ZoneID, poz.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-11-13
07:35 PM
2022-10-05
01:31 PM
Daniel Kassai
2018-11-13
07:35 PM
Hello, I can not change the position of the zone stamp.
The function itself is executed without errors, but the stamp does not move. The documentation indicated will change. For the experiment, changing the name of the zone and everything works with it. Started from the AC17 to the AC21 reached everywhere the same thing.
GSErrCode ModifyZonePoz(const API_Guid &guid)
API_Element element;
API_Element mask;
GSErrCode err;
BNZeroMemory(&element, sizeof(API_Element)); // AC17-AC22 element.header.index
ACAPI_ELEMENT_MASK_CLEAR (mask);
ACAPI_ELEMENT_MASK_SET (mask, API_ZoneType, pos);
//ACAPI_ELEMENT_MASK_SET(mask, API_ZoneType, roomName);
element.zone.pos.x = 5.0;
element.zone.pos.y = 10.0;
//CHCopyC ("test", element.zone.roomName);
element.header.guid = guid; // в заголовок поместить Guid
element.header.typeID = API_ZoneID; // обязательно !
err = ACAPI_Element_Change(&element, &mask, NULL, 0, true);
WriteReport("ACAPI_Element_Change %ld", err);
return err;
What threatens me if, instead of this function, I copy all the properties of the zone and change the memo, then create a new one? ACAPI_Element_Create?Solved! Go to Solution.
Labels:
- Labels:
Add-On (C++)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-11-14 09:29 PM
2018-11-14
09:29 PM
thank you for pointing out this issue! Unfortunately it's a bug, we will work on it.
As a workaround you can create a new zone with the modified stamp position and delete the original one:
Regards,
Tibor
GSErrCode ModifyZonePos (const API_Guid& guid, const API_Coord& newPos)
API_ElementMemo memo;
GSErrCode err;
BNZeroMemory (&element, sizeof (API_Element));
BNZeroMemory (&memo, sizeof (API_ElementMemo));
// get actual zone
err = ACAPI_Element_Get (&element);
if (err == NoError)
err = ACAPI_Element_GetMemo (element.header.guid, &memo);
if (err != NoError)
return err;
// modify pos and create a new zone
element.zone.pos = newPos;
err = ACAPI_Element_Create (&element, &memo);
ACAPI_DisposeElemMemoHdls (&memo);
// delete original zone
API_Elem_Head** heads = (API_Elem_Head**) BMhAllClear (sizeof (API_Elem_Head));
(*heads).guid = guid;
ACAPI_Element_Delete (heads, 1);
BMhKill ((GSHandle*) &heads);
return err;
Regards,
Tibor
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-11-14 09:29 PM
2018-11-14
09:29 PM
Regards,
Tibor
GSErrCode err;
// get actual zone
if (err == NoError)
if (err != NoError)
return err;
return err;
Regards,
Tibor
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-11-15 04:55 PM
2018-11-15
04:55 PM
Thank you Tibor Lorántfy, your code helped a lot, and saved a lot of time, considering my level of understanding of x2 pointers. However, I slightly modified it.
GSErrCode ModifyZonePos(const API_Guid& guid, const API_Coord& newPos)
GSErrCode err;
BNZeroMemory(&memo, sizeof(API_ElementMemo));
// get actual zone
err = ACAPI_Element_Get(&element);
if (err == NoError)
err = ACAPI_Element_GetMemo(element.header.guid, &memo);
if (err != NoError)
return err;
// delete original zone, before create a new zone, if not want get alert
API_Elem_Head** heads = (API_Elem_Head**)BMhAllClear(sizeof(API_Elem_Head));
(*heads)[0].guid = guid; // 0 -1 zones
ACAPI_Element_Delete(heads, 1);
BMhKill((GSHandle*)&heads);
err = ACAPI_Element_Create(&element, &memo);
ACAPI_DisposeElemMemoHdls(&memo);
return err;
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-11-15 06:11 PM
2018-11-15
06:11 PM
ufo_ru wrote:Please note that the parameters of ACAPI_Element_Delete will change in ARCHICAD 23, so you won't have to bother with pointers anymore:
// Before AC23: GSErrCode ACAPI_Element_Delete (API_Elem_Head **elemHead, Int32 nItem); // Since AC23: GSErrCode ACAPI_Element_Delete (const GS::Array<API_Guid>& elemGuids);The sample code in API23 will be much shorter:
API_Element element = {};
API_ElementMemo memo = {};
GSErrCode err;
// get actual zone
if (err == NoError)
if (err != NoError)
return err;
ACAPI_Element_Delete({guid});
return err;
