We value your input!
Archicad C++ API
Getting started with Archicad Add-Ons - problem
szcsaba87
I've recently started learning API. I stuck at the very beginning with the use of template.
In VS I see two problems:
- There is no CMakeCommon.cmake file in my Tools folder.
Unknown CMake command "SetGlobalCompilerDefinitions".
What's wrong?
Thanks
1 REPLY 1
Hi!
Are you using the following template? https://github.com/GRAPHISOFT/archicad-addon-cmake
If so, then I think you are missing this submodule: https://github.com/GRAPHISOFT/archicad-addon-cmake-tools
You should clone the template (first link) as described in the readme with
git clone https://github.com/GRAPHISOFT/archicad-addon-cmake.git --recurse-submodules
and also follow the other steps described in the readme.
Hope that helps!
Bernd
