Cosminn
How do i create my first apx.file, similar with "Roofmaker12
Hello everyone, i need some advices for create one apx file similar with "Roofmaker12". Is there any chance to view the script for "Roofmaker", and what software , (C++)?
Thanks a lot.
Sincerely,
Daniel
Thanks a lot.
apx files are add-ons (plug-ins) for ArchiCAD programmed in C++ using the API Developer Kit.
More information on getting started - including required tools - is here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=36448
and here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=27340
and some slightly out-of-date details are here:
http://www.archicadwiki.com/Developer/Getting%20Started%20with%20the%20API%20DevKit
You may not see the code for Roofmaker or any other production add-ons from Graphisoft - the code is proprietary. However, the API DevKit comes with a fairly large library of sample add-ons (each demonstrating some basic techniques) to help people get started.
Karl
Cosminn
Thanks Karl
Sincerely,
Daniel
