2 weeks ago
Hi everyone,
I'm developing an Archicad Add-On using the C++ API and need to retrieve custom fields that were manually added in the "Project Info" dialog (File > Info > Project Info).community.graphisoft.com
I understand that API_ProjectNoteInfo provides access to standard fields like projectName, client, and company. However, it doesn't seem to include any custom fields added by the user.
Is there a way to programmatically access these custom fields using the Archicad C++ API?
Any guidance or examples would be greatly appreciated.
Thank you!
Solved! Go to Solution.
2 weeks ago
To read custom fields, use the APIAny_GetAutoTextsID function (named ACAPI_AutoText_GetAutoTexts in versions 27/28) with the parameter API_AutotextType type = APIAutoText_Custom. Refer to the API sample code in Goodie_Functions.cpp for implementation examples.
Structural engineer, developer of free addon for sync GDL param and properties
2 weeks ago
2 weeks ago
Thank you sir, it works!
