Le Tan Kien
How to catch event when change parameter, delete, create, move (column, beam, wall,..)
Hi there,
I want to catch event when change parameter, delete, create, move (column, beam, wall, object,..)
Is there a way to do this using the C++ API?
Could you please guide me on how to do it? Thank you very much.
1 Solution
Hi!
You are looking for ACAPI_Element_AttachObserver, ACAPI_Element_CatchNewElement and related functions.
It's best to check the file Element_Observer.cpp in the Notification_Manager example that comes with the API DevKit.
Hope that helps,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Go to post
Hi!
Hope that helps,
Bernd
Le Tan Kien
Thank you sir
