2022-09-24 03:03 PM
hello.
Always I am indebted.
I tried making a RollDownPalette by referring to the BasicElementIconsRollDownDialog in the DG_Test sample.
I'm in trouble because I can't make it a docking palette.
When creating a general palette by inheriting the Palette class, in the constructor
const GS::Guid TestPaletteGuid{ "C67E8137-A2AC-42FD-BDE6-413F509731B8" };
// constructor
TestPalette::TestPalette()
: DG::Palette(ACAPI_GetOwnResModule(), ID_TEST_PALETTE, ACAPI_GetOwnResModule(),
TestPaletteGuid)
I know that you can make it a docking palette by specifying a Guid like this.
However, in order to create a RollDownPalette, you must inherit the RollDownPalette class instead of the Palette class,
I wrote this in the constructor, but it doesn't dock.
// constructor
TestPalette::TestPalette(DG::NativePoint* posistion)
:UD::RollDownPalette(TestPaletteGuid, posistion, Close)
A Guid is given to the constructor of the base class, but this Guid may not be inherited to the Palette of the base class.
I also thought that there might be other constructors, so I searched for other constructors of the RollDownPalette class, but found only these constructors.
RollDownPalette (const GS::Guid& guid, CloseType closeType = NoClose,
CaptionType captionType = TopCaption, FrameType frameType = NormalFrame);
RollDownPalette (const GS::Guid& guid, const DG::NativePoint* position = nullptr,
CloseType closeType = NoClose, CaptionType captionType = TopCaption,
Since there is a RollDownPalette that is docked with the palettes provided in Archicad (for example, the toolbox docked at the left end of the screen), I think it will be possible...
If you know how to dock the RollDownPalette, please let me know.
Thank you.
2022-09-26 05:35 PM
For a palette to be dockable, it has to have the noGrow argument in the grc file:
'GDLG' JKSRFTOOLS_JKPLT_RESID Palette | leftCaption | noGrow | close 0 0 80 34 "JKPalette Example" {
/* [ 1] */ IconButton 5 2 30 30 JKSettings_IconId
/* [ 2] */ IconButton 40 2 30 30 JKZoneToolLarge_IconId
2022-10-01 02:53 PM
julien quadra
Thank you for your reply.
However, I think that the argument to be added to the grc file is not noGrow but grow.
Another common palette that I have implemented is docking with argument grow and not docking with noGrow.
Please try it in your environment.
Also, the problem in this thread is not a general palette that inherits the DG::Palette class as you replied
A special palette that inherits from the UD::RollDownPalette class.
I made a simple sample. (attached image)
This is the undocked state, but it's working fine in our environment.
This roll-down palette has a structure like a parent with multiple tab pages as children,
Each tab page has its own resources and classes.
The parent page has a class but no resources.
(The resource in the green part of the image is just the text provided for the child palette heading)
I also wanted to specify grow as an argument if the parent resource exists
Cannot be specified because the resource itself does not exist.
I think that the child tab page is probably not related to docking
These are also tab pages, not palettes, so I don't think grc has any items related to docking.
It may be a difficult problem, but if there is someone with knowledge
I would like you to help me.
Thank you.
