ā2020-07-22
11:25 AM
ā2021-09-15
10:33 AM
Noemi Balogh
Solved! Go to Solution.
ā2020-07-22 12:13 PM
'STR#' 32500 "My menu strings" {
/* [ 1] */ "My Main Menu"
/* [ 2] */ "My Menu^E3"
See more informations here: ā2020-07-22 11:41 AM
See more informations here: ā2020-07-22 12:29 PM
ā2020-07-23 11:53 AM
Tibor wrote:Hi Tibor.
Hi scandi,
If you register a new menu item from an Add-On by default it will be enabled (not gray) only when a 2D view (floorplan) is active.
But you can enable your menu items under any other view types if you modify the resource string of your menu item in your GRC file. Simply add ^E3 (= Enable in 3D) after the string title of your menu item into the GRC and it won't be gray and you will be able to use ACAPI_3D_GetCurrentWindowSight:'STR#' 32500 "My menu strings" { /* [ 1] */ "My Main Menu" /* [ 2] */ "My Menu^E3" }See more informations here:http://archicadapi.graphisoft.com/documentation/required-resources
ā2020-07-23 11:59 AM
scandi wrote:I find it! "^D2" will work. Maybe D2 means "Disable in 2D".
Hi scandi,
Could you please tell me how to enable the button only in 3D window please? Is there a disable-2D string?
Thanks in advance!
ā2020-07-23 01:31 PM
scandi wrote:Follow the link Tibor gave you - it provides all the documentation for the menu resources:
ā2020-07-23 06:54 PM
Ralph wrote:Thank you. I didn't notice that link.
I find it! "^D2" will work. Maybe D2 means "Disable in 2D".http://archicadapi.graphisoft.com/documentation/required-resources
