How to get sightPtr
Hi guys.
I would like to export model from ARCHICAD. Different from ModelAccess_Test module which triggers the functions by "save", the requirement is to click the button on the menu. However, if I install menu handler, I could not get Modeler::SightPtr like Install_FileTypeHandler3D. I was wondering how to get Modeler::SightPtr in some other ways.
Thanks in advance.
1 Solution
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi scandi,
If you register a new menu item from an Add-On by default it will be enabled (not gray) only when a 2D view (floorplan) is active.
But you can enable your menu items under any other view types if you modify the resource string of your menu item in your GRC file. Simply add ^E3 (= Enable in 3D) after the string title of your menu item into the GRC and it won't be gray and you will be able to use ACAPI_3D_GetCurrentWindowSight:
'STR#' 32500 "My menu strings" {
/* [  1] */     "My Main Menu"
/* [  2] */         "My Menu^E3"
See more informations here: http://archicadapi.graphisoft.com/documentation/required-resources
Go to post
8 Replies 8
I use ACAPI_3D_GetCurrentWindowSight but when the button is gray in 3D window...When I click it in the non-3D window, ACAPI_3D_GetCurrentWindow returns bad window.
Could anybody be so kind as to help me please?
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi scandi,
Thank you Tibor! I got it.
Tibor wrote:
Hi scandi,
Hi Tibor.
Could you please tell me how to enable the button only in 3D window please? Is there a disable-2D string?
Thanks in advance!
scandi wrote:
Tibor wrote:
Hi scandi,
Hi Tibor.
Thanks in advance!
I find it! "^D2" will work. Maybe D2 means "Disable in 2D".
Ralph Wessel
Follow the link Tibor gave you - it provides all the documentation for the menu resources: http://archicadapi.graphisoft.com/documentation/required-resources
Ralph Wessel BArch
Central Innovation
Thank you. I didn't notice that link.
