2015-01-21 01:50 PM - last edited on 2023-08-01 01:53 PM by Doreena Deng
// ----------------------------------------------------------------------------- // Set/adjust the dialog items // ----------------------------------------------------------------------------- static void ListDataDlg_Set (short dialId, DGUserData userData) { API_ListData listdata; char keyStr[NAME_LEN2]; char codeStr[NAME_LEN2]; Int32 count; Int32 i; bool filter; if (userData == 0L) { return; } listdata = *((API_ListData *) (userData)); listdata.header.setIndex = (short) DGPopUpGetItemUserData (dialId, DBSetPopupItem, (short) DGGetItemValLong (dialId, DBSetPopupItem)); GS::UniString temp = DGGetItemText (dialId, KeyEditTextItem); CHTruncate (UniStringToConstCString (temp), keyStr, NAME_LEN2); temp = DGGetItemText (dialId, CodeEditTextItem); CHTruncate (UniStringToConstCString (temp), codeStr, NAME_LEN2); switch (DGGetItemValLong (dialId, TypeIDPopupItem)) { case 1: listdata.header.typeID = API_ComponentID; CHCopyC (keyStr, listdata.component.keycode); CHCopyC (codeStr, listdata.component.code); DGEnableItem (dialId, KeyEditTextItem); break; case 2: listdata.header.typeID = API_DescriptorID; CHCopyC (keyStr, listdata.descriptor.keycode); CHCopyC (codeStr, listdata.descriptor.code); DGEnableItem (dialId, KeyEditTextItem); break; case 3: listdata.header.typeID = API_KeyID; CHCopyC (codeStr, listdata.key.code); DGDisableItem (dialId, KeyEditTextItem); break; case 4: listdata.header.typeID = API_UnitID; CHCopyC (codeStr, listdata.unit.code); DGDisableItem (dialId, KeyEditTextItem); break; } DGListDeleteItem (dialId, SearchListItem, DG_ALL_ITEMS); filter = (DGGetCheckedRadio (dialId, 1) == FilterRadioItem); Search_ListData (&listdata, &count, filter); if (count < 1 || listHdl == NULL) return; for (i = 1; i <= count; i++) DGListInsertItem (dialId, SearchListItem, DG_LIST_BOTTOM); SetDGList (dialId, count); DGListSelectItem (dialId, SearchListItem, 1); return; } // ListDataDlg_Set static void Search_ListData (API_ListData *param, Int32 *count, bool filter) { API_ListData listdata; Int32 i; Int32 beginIndex, endIndex; GSErrCode err; listdata = *param; *count = 0; err = NoError; /* ACAPI_ListData_Search fails if keyCode is an empty string */ /* ------- Search it ------- */ if (filter && (param->header.typeID == API_UnitID || param->header.typeID == API_KeyID || (param->header.typeID == API_ComponentID && strlen (param->component.code) != 0) || (param->header.typeID == API_DescriptorID && strlen (param->descriptor.code) != 0))) { err = ACAPI_ListData_Search (&listdata); if (err == NoError) err = ACAPI_ListData_Get (&listdata); if (err == NoError) { err = AppendList (&listdata, count); if (listdata.header.typeID == API_DescriptorID) BMKillHandle (&listdata.descriptor.name); } } else { /* ------ Search list ------ */ if (filter) { err = ACAPI_ListData_Search (&listdata); if (err != NoError) return; beginIndex = listdata.header.index; } else beginIndex = 1; err = ACAPI_ListData_GetNum (param->header.setIndex, param->header.typeID, &endIndex); if (err != NoError) return; BNZeroMemory (&listdata, sizeof (API_ListData)); listdata.header.typeID = param->header.typeID; listdata.header.setIndex = param->header.setIndex; for (i = beginIndex; i <= endIndex; i++) { listdata.header.index = i; err = ACAPI_ListData_Get (&listdata); if (err != NoError) break; if (filter) { if (listdata.header.typeID == API_ComponentID && !CHEqualCStrings (listdata.component.keycode, param->component.keycode)) break; if (listdata.header.typeID == API_DescriptorID && !CHEqualCStrings (listdata.descriptor.keycode, param->descriptor.keycode)) { BMKillHandle (&listdata.descriptor.name); break; } } if (err == NoError) { err = AppendList (&listdata, count); if (listdata.header.typeID == API_DescriptorID) BMKillHandle (&listdata.descriptor.name); } if (err != NoError) return; } } return; } // Search_ListDataBut how can I group those items under a header like in the example.
2015-01-28 04:03 AM
2015-01-28 09:14 AM
2015-08-20 08:54 AM
bool isOpen = false; //... clear list before loop for (... i = 0; i < cnt; i++) { if (flags & API_ParFlag_Hidden) continue; // check if parent or child if (flags & API_ParFlag_Child) { // skip if parent is "close" if (!isOpen) continue; } // set isOpen if item is not child else { isOpen = (flags & API_ParFlag_Open) > 0; } //... populate list here checking if it is disabled, bold, separator, etc. }
2015-08-21 12:11 PM
