sxs
How to switch to 3d window by ACAPI?
Hi,everyone:
GSErrCode err = ACAPI_Sight_SelectSight (nullptr, &origSight);
if (err != NoError) {
	ErrorBeep ("Cannot switch to the 3D sight", err);
	return err;
  I  try this to switch to the 3d window, but it does not work.
1 Solution
sxs
		API_WindowInfo      windowInfo;
		API_DatabaseInfo    origDB, planDB;
		API_Element         element;
		GS::Array<API_Guid> elemList;
		GSErrCode           err;
		BNZeroMemory(&planDB, sizeof(API_DatabaseInfo));
		planDB.typeID = APIWind_3DModelID;
		//ACAPI_Database(APIDb_GetCurrentDatabaseID, &origDB, nullptr);
		ACAPI_Database_ChangeCurrentDatabase(&planDB);
		BNZeroMemory(&windowInfo, sizeof(API_WindowInfo));
		windowInfo.typeID = APIWind_3DModelID;
		windowInfo.databaseUnId = planDB.databaseUnId;
		err = ACAPI_Window_ChangeWindow(&windowInfo);
   this can work.
Go to post
6 Replies 6
Ralph Wessel
Call ACAPI_Database_ChangeCurrentDatabase passing APIWind_3DModelID as the API_DatabaseInfo.typeID
Ralph Wessel BArch
Central Innovation
sxs
This API still has no effect, but the return value is NoError. Is it related to my ArchiCad currently running DEMO status?
sxs
		GSErrCode           err;
   this can work.
kolioi
You can use also ACAPI_View_GoToView()
Ralph Wessel
When you say it has no effect, do you mean you don't see the view come to the front? If so, this isn't what ACAPI_Database_ChangeCurrentDatabase does. It makes the 3D window the current database for all following API commands that concern a specific database, e.g. ACAPI_View_Rebuild
If you simply want to bring the view to the front, use ACAPI_Window_ChangeWindow, but I don't think that's what you want to do in the context of a notification handler
Ralph Wessel BArch
Central Innovation
sxs
Ok,I got it
