2016-12-12 09:32 PM - last edited on 2023-07-12 09:02 PM by Doreena Deng
2016-12-14 09:10 AM
IanTr wrote:Hello Ian,
I'm new to Archicad and am looking into a bug whereby shell objects doesn't appear ( I suspect because there isn't an implementation to handle arcs/shell). The original implementer of our archicad codebase left so I'm picking up the pieces so to say.
From what I can tell, we are using ACPI_Goodies(API_RegularizePolyID) to triangulate Archicad primitives. I did fix the case for APIERR_IRREGULARPOLY by using API_RegularizedPolyID. However I'm still seeing error APIERR_REFUSEDPAR return by APIAny_TriangulatePolyID due to arc since the function only accept polygons w/o arc segments. I was just wondering if someone could point me towards tutorial/sample codes/ or how to go about triangulating arcs?
Thanks in advance,
Ian
2016-12-14 08:56 PM
2016-12-15 11:51 AM
IanTr wrote:You could facet the arc edges to the required level of precision first.
According to the API doc, ACAPI_Goodies (APIAny_TriangulatePolyID, ...) only accept polygons that has no arc segments. The code snippet on that page also shows it skips over nArcs > 0. I was just wondering if there are functions/methods that I missed looking through the samples that handles triangulation of arcs.
2016-12-18 11:40 AM
Ralph wrote:Ian,IanTr wrote:You could facet the arc edges to the required level of precision first.
#include "GenArc2DData.h" #include "Ellipse2DData.h" /*----------------------------------------------------------** ** Gets the current ARCHICAD settings for arc division ** **----------------------------------------------------------*/ static double GetMaxDiff () { double maxDiff = EPS; if (ACAPI_Environment (APIEnv_GetExportToleranceID, &maxDiff) != NoError) { API_MagicWandInfo mwi = {0}; if (ACAPI_Environment (APIEnv_GetMagicWandSetsID, &mwi) != NoError) maxDiff = EPS; else maxDiff = mwi.arcDiff; } return maxDiff; } /*----------------------------------------------------------** ** Divides an arc according to the currect AC settings ** **----------------------------------------------------------*/ static GSErrCode DivideArc (const API_Coord& orig, double r, double begAng, double endAng, bool reflected, double ratio, bool elliptic, USize * nCo, Coord** hCo) { GenArc genArc; if (elliptic) { genArc.SetToEllipseArc (Geometry::Ellipse ((const Coord &)orig, r, ratio, 0.0), begAng, endAng, reflected); } else { genArc.SetToCircleArc ((const Coord &)orig, r, begAng, endAng, reflected); } Geometry::DivideEllArcToCo (genArc, GetMaxDiff (), hCo, nCo); return NoError; } /*----------------------------------------------------------** ** Writes out a Circular/Elliptic Arc, divided ** **----------------------------------------------------------*/ static GSErrCode DWF_WrDividedArc (const API_Coord& orig, double r, double begAng, double endAng, bool reflected = false, double ratio = 1.0, bool elliptic = false) { USize nCo = 0; Coord **hCo = reinterpret_cast<Coord **> (BMhAll (0)); GSErrCode lastErr = DivideArc (orig, r, begAng, endAng, reflected, ratio, elliptic, &nCo, hCo); if (lastErr != NoError) { BMhFree ((GSHandle) hCo); return lastErr; } // ... BMhFree ((GSHandle) hCo); return lastErr; }Regards, Akos
