2023-12-14 03:33 PM - last edited on 2024-09-17 01:17 PM by Doreena Deng
I want to learn how to turn off everything except the specified layer.
However, I followed the site below, but not all layers are turned off.
API hide all layers - Graphisoft Community
This site asks questions about changing the above code to version 27.
I found out that the index code only works within the number of layers.
Solved: Re: attrib.header.index = i; is error. - Graphisoft Community
I know how to know the number, but
I don't know what the first index is and what the next index is.
Where should I study?
2023-12-14 03:57 PM
You know this ability is available in the Quick Layers palette ?
I can't help you on the API, but thought I would mention it in case you missed the existing tool.
2023-12-14 05:16 PM - edited 2023-12-14 05:19 PM
thank you This is a question I asked to create an environment while working.
Yes, I am using the quick layer you mentioned well.
I'm asking because there are times when I need to turn on a few disabled layers and turn off all layers while working.
Thank you again for your interest.
Have a nice day.
2023-12-20 10:39 AM
What I want to know is that I can find out the number with getnum. Then how can I get the indices in order?
Is there no way?
2023-12-22 03:47 PM
If you know what the maximum value of the layer index is,
It's okay to search by index from 0 to the maximum value, but is there a function that can find the maximum and minimum values?
2023-12-23 01:25 PM
I think this answer might help you as well:
