2015-03-05
03:01 PM
2023-08-01
01:34 PM
Doreena Deng
2015-03-06 12:23 AM
Traro wrote:Traro,
I would like to ChangeDefaults Door and Window(Change Object).
Ex.
- I have 2 door object [MyDoor1.gsm , MyDoor2.gsm].
- And "MyDoor1" is Defaults object then i would like change to "MyDoor2" object.
2015-03-06 12:00 PM
Traro wrote:I suggest first getting the object defaults with
Ex.
2015-03-06 04:10 PM
Ralph wrote:I absolutely agree with Ralph Wessel using these methods to change the default object. I wrote a code sample based on these methods,Traro wrote:I suggest first getting the object defaults with
Ex.
- And "MyDoor1" is Defaults object then i would like change to "MyDoor2" object.ACAPI_Element_GetDefaults. The critical information required for setting the correct library part is the libIndvalue in the API_ObjectTypestructure. This is a temporary index to the object in the loaded libraries. You can find this using ACAPI_LibPart_Searchwith the name of the target object.
I can't recollect whether it's essential to get the default parameters for this object to set in the tool defaults, but you can get this information usingACAPI_LibPart_GetParams(parameters and default size).
API_LibPart libDoor;
API_Element elementDoor;
API_ElementMemo memo;
GSErrCode err = NoError;
// Get defaults for door element
BNZeroMemory (&elementDoor, sizeof (API_Element));
elementDoor.header.typeID = API_DoorID;
err = ACAPI_Element_GetDefaults (&elementDoor, &memo);
if (err != NoError) {
WriteReport_Alert ("Cannot get door defaults");
return;
// Get a door object from library using its name
BNZeroMemory (&libDoor, sizeof (libDoor));
const GS::UniString uName ("Door with Sidelight on Side 1 19");
GS::ucscpy (libDoor.docu_UName, uName.ToUStr ());
err = ACAPI_LibPart_Search (&libDoor, false);
WriteReport_Alert ("No libpart found with that name");
return;
delete libDoor.location; // don't forget to free location
// Change libInd of the default door to the new one
API_Element mask;
ACAPI_ELEMENT_MASK_CLEAR (mask);
ACAPI_ELEMENT_MASK_SET (mask, API_DoorType, openingBase.libInd);
elementDoor.door.openingBase.libInd = libDoor.index;
err = ACAPI_Element_ChangeDefaults (&elementDoor, &memo, &mask);
WriteReport_Alert ("Cannot change door defaults");
return;
// Check whether defaults were updated
API_Element elementDoor2;
elementDoor2.header.typeID = API_DoorID;
err = ACAPI_Element_GetDefaults (&elementDoor2, NULL);
return;
if (elementDoor2.door.openingBase.libInd != libDoor.index) {
WriteReport_Alert ("Door default settings were not updated");
return;
This example changes only the default door object nothing more (e.g. not using default parameters of this door object).2015-03-11 09:31 AM
2015-03-13 02:58 PM
API_Element mask;
+ // Set default params of the new door object
+ double a, b;
+ Int32 addParNum;
+ API_AddParType **addPars;
+ err = ACAPI_LibPart_GetParams (libDoor.index, &a, &b, &addParNum, &addPars);
+ if (err) {
+ WriteReport_Alert ("Cannot get libpart params");
+ return;
+ memo.params = addPars;
return;
+ ACAPI_DisposeElemMemoHdls (&memo);
