Archicad C++ API
I would like to know how to create a wall using Wall Geometry Method:Polygonal.
LeeJaeYoung
I would like to know how to create a wall using Wall Geometry.
What sample code can I study?
AC27 on window 11
8 REPLIES 8
Tim Ball
I work on old buildings a lot where wall thicknesses vary and often are not even parallel. You can either draw the polygon directly or trace over a survey drawing using the space bar click.
Tim Ball
AC26, iMac
User since V5
thank you.
This is the c++ api forum. ^^
I found Polygon in API_WallType. I think I'll probably use this.
I don't know if it's true.
It hasn't been tested yet.
AC27 on window 11
Yes that's what you are looking for. You will have to use the polygon data in the memos.
Something like this:
GSErrCode CreatePolyWall ()
  API_Element element {};
  element.header.type = API_WallID;
  ACAPI_Element_GetDefaults (&element, nullptr);
  element.wall.type = APIWtyp_Poly;
  element.wall.modelElemStructureType = API_BasicStructure;
  element.wall.poly.nCoords = 5;
  element.wall.poly.nSubPolys = 1;
  element.wall.poly.nArcs = 0;
  API_ElementMemo memo{};
  memo.coords = reinterpret_cast<API_Coord**> (
    BMAllocateHandle (sizeof (API_Coord) * (element.wall.poly.nCoords + 1), ALLOCATE_CLEAR, 0));
  if (memo.coords == nullptr) { return APIERR_MEMFULL; }
  (*memo.coords)[0] = { 0.0, 0.0 }; // always has to be (0,0)
  (*memo.coords)[1] = { 0.0, 0.0 };
  (*memo.coords)[2] = { 1.0, 0.0 };
  (*memo.coords)[3] = { 1.0, 1.0 };
  (*memo.coords)[4] = { 0.0, 1.0 };
  (*memo.coords)[5] = (*memo.coords)[1];
  memo.pends = reinterpret_cast<Int32**> (
    BMAllocateHandle (sizeof (Int32) * (element.wall.poly.nSubPolys + 1), ALLOCATE_CLEAR, 0));
  if (memo.pends == nullptr) { return APIERR_MEMFULL; }
  (*memo.pends)[0] = 0;
  (*memo.pends)[1] = 5; //index of polygon closing coordinate/vertex
  memo.vertexIDs = reinterpret_cast<UInt32**> (
    BMAllocateHandle (sizeof (UInt32) * (element.wall.poly.nCoords + 1), ALLOCATE_CLEAR, 0));
  if (memo.vertexIDs == nullptr) { return APIERR_MEMFULL; }
  (*memo.vertexIDs)[0] = element.wall.poly.nCoords;
  for (Int32 vIdx = 1; vIdx <= element.wall.poly.nCoords; ++vIdx) {
    (*memo.vertexIDs)[vIdx] = vIdx;
  memo.edgeIDs = reinterpret_cast<UInt32**> (
  if (memo.edgeIDs == nullptr) { return APIERR_MEMFULL; }
  (*memo.edgeIDs)[0] = 0;
  for (Int32 eIdx = 1; eIdx <= element.wall.poly.nCoords; ++eIdx) {
    (*memo.edgeIDs)[eIdx] = eIdx;
  GSErrCode err = ACAPI_Element_Create (&element, &memo);
  ACAPI_DisposeElemMemoHdls (&memo);
  return err;
Bernd Schwarzenbacher - Archicad Add-On Developer - Get Add-Ons & Archicad Tips on my Website: bschwb.com
kency
@BerndSchwarzenbacher @LeeJaeYoung
For me, Archicad crashes with this change when the add-on is invoked. Only if I explicitly change the Wall structure to Basic and invoke the add-on it renders without crashing. I have also tried this on Archicad 26 and 27 and the non-demo version. Please watch the loom video linked here.
Is there any setting that we can use to avoid this? Rather than requesting the user to choose Basic Structure?
I am using MacOS.
Hi Kency,
I was able to reproduce the same issue as you have. It's very weird and I can't think of any explanation why it is like that.
It could be a bug in the API. So you could put a bug report for it with the developer support.
Best,
Bernd
kency
Adding the Bug report link here for other community members to track
Viktor Kovacs
Seems like a bug. Does it crash even if you explicitly set the wall type to basic in the code?
Yes both in the video from kency and in my tests the wall type was explicitly set to basic and we get a crash.
