[LibPart] Placing on scene from plugin
Hello,
I need to place LibPart using API functions from plugin. Simple Example:
I've defined box.gsm:
XFORM 1, cos(alfa), 0, 0,
	0, 1, 0, 0,
	0, 0, 1, 0
BLOCK A, B, 1
I've added path to it in plugin:
IO::Location rab("D:/GDLobjects/");
if(!rab.IsValid())
	throw ElementException("bad location");
if(ACAPI_Environment (APIEnv_AddLibrariesID, reinterpret_cast<void *>(&rab), NULL) == NoError)
	_interface->GetReporter().Report("folder added");
else
	throw ElementException("registering location failed");
And successfully founded and loaded it to memory:
API_LibPart part;
GSErrCode err;
BNZeroMemory(&part, sizeof(API_LibPart));
CHANSI2Unicode("box.gsm", strlen("box.gsm"), part.file_UName, API_UniLongNameLen);
if((err = ACAPI_LibPart_Search(&part, false)) == NoError)
	if((err = ACAPI_LibPart_Get(&part)) == NoError)
		// place on specified location
	else
		_interface->GetReporter().Report(err);
else
BUT!!!
I haven't found any function in ACAPI_LibPart_* to place it on scene and pass parameters to it (like: A, B, alfa);
Do anyone have examples how to do it...
Thanks for help, I need it badly
-edit-
I found ACAPI_LibPart_ShapePrims, but i have no idea how to use it 😕
Ralph Wessel
You've looked up the definition of a library part, but now you want to place an instance of it. They are completely different things.
To place an object in the plan, for example, you need to populate an element data structure, in this case the 'object' member of API_Element (which is of type API_ObjectType), and writing it to the element database with ACAPI_Element_Create.
Take a look at APIAny_OpenParametersID (and associated functions) for setting parameter values.
Ralph Wessel BArch
Central Innovation
Helped a LOT!!!
Thanks!
API_Element element;
API_ElementMemo memo;
BNZeroMemory(&element, sizeof(API_Element));
BNZeroMemory(&memo, sizeof(API_ElementMemo));
double A = 0;
double B = 0;
long parCount = 0;
element.header.typeID = API_ObjectID;
ACAPI_Element_GetDefaults(&element, &memo);
ACAPI_LibPart_GetParams(part.index, &A, &B, &parCount, &memo.params);
element.object.angle = 0;
element.object.pos.x = 0 + i;
element.object.pos.y = 0 + ii;
element.object.xRatio = A;
element.object.yRatio = B;
element.object.libInd = part.index;
ACAPI_Element_Create(&element, &memo);
