2021-04-27
03:13 AM
- last edited on
2021-09-14
09:39 AM
by
Noemi Balogh
void Do_CreateLine(API_Guid guid)
API_Coord c;
API_GetLineType clickInfo;
API_Element element;
GSErrCode err;
// input the coordinates
BNZeroMemory(&clickInfo, sizeof(API_GetLineType));
if (!ClickAPoint("Click the line start point", &c))
return;
CHCopyC("Click the line end point", clickInfo.prompt);
clickInfo.startCoord.x = c.x;
clickInfo.startCoord.y = c.y;
err = ACAPI_Interface(APIIo_GetLineID, &clickInfo, nullptr);
if (err != NoError) {
ErrorBeep("APIIo_GetLineID", err);
return;
// real work
BNZeroMemory(&element, sizeof(API_Element));
element.header.typeID = API_LineID;
ACAPI_Element_GetDefaults(&element, nullptr);
ErrorBeep("ACAPI_Element_GetDefaults (Line)", err);
return;
element.header.renovationStatus = API_DemolishedStatus;
element.line.begC.x = clickInfo.startCoord.x;
element.line.begC.y = clickInfo.startCoord.y;
element.line.endC.x = clickInfo.pos.x;
element.line.endC.y = clickInfo.pos.y;
err = ACAPI_Element_Create(&element, nullptr);
ErrorBeep("ACAPI_Element_Create (Line)", err);
ACAPI_WriteReport("Create Error = %s", true, ErrID_To_Name(err));
return;
else
ACAPI_WriteReport("Create Success - %s", true, "No Error");
ACAPI_WriteReport("GUID of the Line: %s", true, APIGuidToString(element.header.guid).ToCStr().Get());
guid = element.header.guid; // store it for later use
ACAPI_KeepInMemory(true);
return;
} // Do_CreateLine
Solved! Go to Solution.
2021-04-27 04:18 PM
2021-04-27 09:05 AM
2021-04-27 12:40 PM
static GSErrCode MenuCommandHandler (const API_MenuParams *menuParams)
GS::ErrCode err;
return ACAPI_CallUndoableCommand("Element Test API Function",
[&]() -> GSErrCode {
switch (menuParams->menuItemRef.menuResID) {
case AddOnMenuID:
switch (menuParams->menuItemRef.itemIndex) {
case 1:
err = Do_PlaceKeySymbol("part");
break;
case 2:
Do_CreateLabel();
break;
case 3:
Do_CreateLine(APINULLGuid);
break;
default: break;
return err;
Note that the first function that just creates a library Part works OK.2021-04-27 04:18 PM
