MFC usage with Archicad Add on
I have created add-ons for 4 other CAD/3D applications, and have a complex set of MFC based dialogs already built.
I would like to use those same dialogs for an Archicad Add On. Looking at the forum, there does not seem to be support for this? Has anyone found a way?
4 Replies 4
stefan
FWIW, MFC will be useless for a user on macOS.
The DevKit only supports using the Graphisoft provided dialog resource methods. For anything beyond that, I guess you are on your own. I think you either use the method provided or may fall back on using a Browser component and a Web UI.
Archicad-user since 1998
my Archicad Book
I have created a separate DLL with my dialogs, and call them from my Archicad plugin.
This has allowed me to keep my dialogs (and dialog logic) consistent will my other apps.
Dear MG_NV,
Could you say, what you used for creating UI, that's in your DLL? MFC, Qt, or maybe WPF)))
I used MFC
