Newbie questions
Hi there!
First of all I've got a problem starting the development since I dont really know how to get started.
I mean, Iv'e got much experience with programming, but no clue when it comes to using programming for archicad.
Where do I start? I mean, how do I use my code in archicad?
furthermore, how can I get an access to the project properties, for example how can I actually get the actual number of floors in my project? etc...
thanks!
6 Replies 6
First page to visit:
http://www.graphisoft.com/support/developer/
Download the API kit from here:
http://www.graphisoft.com/support/developer/downloads/index.html
Get the documentation from here:
http://www.graphisoft.com/support/developer/documentation/index.html
Ralph Wessel
BBman wrote:
Hi there!
You'll need either XCode for the Mac OS or Visual Studio 2005 for Windows, and should be reasonably proficient in C (ideally C++).
Laszlo has given you all the relevant links to the API and documentation. It's mostly a matter of reading the documentation and looking through the examples. Your add-on code is ultimately built into a DLL that is loaded by ArchiCAD as required.
Information about storys (floors) is retrieved by calling the function ACAPI_Environment with the identifier APIEnv_GetStorySettingsID.
Ralph Wessel BArch
Central Innovation
Thx.
Well, Iv'e got the visual studio 2010, will it do the work?
Ralph Wessel
Possibly, but I don't recommend trying. You will save yourself a lot of trouble if you stick to the specified development environment.
Ralph Wessel BArch
Central Innovation
stefan
Where is the API documentation? It is not visible on that page. Only library, LP_XMLConvertor and ODBC driver
Archicad-user since 1998
my Archicad Book
Ralph Wessel
That page is a bit misleading. The documentation for the API is bundled with the API developer kit at: http://www.graphisoft.com/support/developer/downloads/
Ralph Wessel BArch
Central Innovation
