2020-07-24
07:26 PM
- last edited on
2021-09-15
10:31 AM
by
Noemi Balogh
2020-07-26 09:17 PM
juliencuadra wrote:Yes, it's possible.
- Is it possible to make an add-on palette dockable like the default archicad palettes to integrate it nicely in the UI.
Palette (GSResModule resModule, short resId, GSResModule dialIconResModule, const GS::Guid& guid);And do not forget to register your palette as a modeless window by using ACAPI_RegisterModelessWindow function.
static const GS::Guid paletteGuid ("{ED852AD6-15E7-4812-AD88-FA1682E5D33C}");
MyPalette::MyPalette () :
DG::Palette (ACAPI_GetOwnResModule (), MyPaletteResId, ACAPI_GetOwnResModule (), paletteGuid),
GSErrCode __ACENV_CALL PaletteControlCallBack (Int32, API_PaletteMessageID messageID, GS::IntPtr param)
switch (messageID) {
case APIPalMsg_OpenPalette:
if (!HasInstance ())
CreateInstance ();
GetInstance ().Show ();
break;
case APIPalMsg_ClosePalette:
break;
GetInstance ().Hide ();
break;
case APIPalMsg_HidePalette_Begin:
if (HasInstance () && GetInstance ().IsVisible ())
break;
case APIPalMsg_HidePalette_End:
if (HasInstance () && !GetInstance ().IsVisible ())
break;
case APIPalMsg_DisableItems_Begin:
GetInstance ().DisableItems ();
break;
case APIPalMsg_DisableItems_End:
GetInstance ().EnableItems ();
break;
case APIPalMsg_IsPaletteVisible:
*(reinterpret_cast<bool*> (param)) = HasInstance () && GetInstance ().IsVisible ();
break;
default:
break;
return NoError;
GSErrCode __ACENV_CALL Initialize (void)
GSErrCode err = ACAPI_RegisterModelessWindow (
GS::GenerateHashValue (paletteGuid),
PaletteControlCallBack,
API_PalEnabled_FloorPlan + API_PalEnabled_Section + API_PalEnabled_Elevation +
API_PalEnabled_InteriorElevation + API_PalEnabled_3D + API_PalEnabled_Detail +
API_PalEnabled_Worksheet + API_PalEnabled_Layout + API_PalEnabled_DocumentFrom3D,
GSGuid2APIGuid (paletteGuid));
return err;
- The API documentation only mentions palettes, not toolbars. Is it possible to create toolbars, also dockable like the archicad ones ?
'GDLG' 32500 Palette | topCaption | close | noGrow 0 0 450 150 "My Toolbar" {
2020-07-26 10:44 PM
2020-08-03 04:59 PM
