Archicad C++ API
RenamePublisherItem from Navigator example crashes at second/third call?
I am trying to use the RenamepublisherItem void from the Navigator_Test example.
When I use it twice or more (it changes), AC crashed.
The error is - Exception thrown around 0x00007FF939B2D84C (objectdatabase.dll) in Archicad.exe: 0XC000005: Access violation reading location 0x0000000000000008
I read it’s related to memory but couldn’t find the problem..
Thanks in advance
6 REPLIES 6
The error is - Exception thrown around 0x00007FF939B2D84C (objectdatabase.dll) in ARCHICAD.exe: 0XC000005: Access violation reading location 0x0000000000000008
Thanks in advance
Also happened to me a couple of times. Can't figure out why it won't work the second/third time.
I have a similar problem, I’ll be happy for a solution too!
Anyone has an idea?
akomporday
Graphisoft Alumni
Hey guys,
Could you show the context where you wanted to use the function?
akomporday wrote:
Hey guys,
I want to use it just the way it was written at the navigator example.
Anyone?
