Roof creation
Hi All,
Do you have any sample code how to create a roof from a set of points on a single plane?
Thanks,
Andor
2 Replies 2
Tibor Lorantfy
Hi Andor,
I wrote a short sample code for you:
// Create a Single-plane Roof
void	Do_CreatePlaneRoof (API_Coord centerPoint)
	API_Element element;
	BNZeroMemory (&element, sizeof (API_Element));
	element.header.typeID = API_RoofID;
	element.roof.roofClass = API_PlaneRoofID;
	GSErrCode err = ACAPI_Element_GetDefaults (&element, NULL);
	if (err != NoError) {
		ErrorBeep ("ACAPI_Element_GetDefaults (roof)", err);
		return;
	API_ElementMemo memo;
	BNZeroMemory (&memo, sizeof (API_ElementMemo));
	// constructing planeRoof data
	element.roof.u.planeRoof.poly.nCoords	= 8;
	element.roof.u.planeRoof.poly.nSubPolys	= 2;
	element.roof.u.planeRoof.poly.nArcs		= 2;
	memo.coords = reinterpret_cast<API_Coord**> (BMAllocateHandle ((element.roof.u.planeRoof.poly.nCoords + 1) * sizeof (API_Coord), ALLOCATE_CLEAR, 0));
	memo.pends = reinterpret_cast<Int32**> (BMAllocateHandle ((element.roof.u.planeRoof.poly.nSubPolys + 1) * sizeof (Int32), ALLOCATE_CLEAR, 0));
	memo.parcs = reinterpret_cast<API_PolyArc**> (BMAllocateHandle (element.roof.u.planeRoof.poly.nArcs * sizeof (API_PolyArc), ALLOCATE_CLEAR, 0));
	if (memo.coords == NULL || memo.pends == NULL || memo.parcs == NULL) {
		ErrorBeep ("Not enough memory to create roof polygon data", APIERR_MEMFULL);
		ACAPI_DisposeElemMemoHdls (&memo);
		return;
	// contour points:
	(*memo.coords)[1].x = centerPoint.x + 10.0;
	(*memo.coords)[1].y = centerPoint.y + 10.0;
	(*memo.coords)[2].x = centerPoint.x + 10.0;
	(*memo.coords)[2].y = centerPoint.y - 10.0;
	(*memo.coords)[3].x = centerPoint.x - 10.0;
	(*memo.coords)[3].y = centerPoint.y - 10.0;
	(*memo.coords)[4].x = centerPoint.x - 10.0;
	(*memo.coords)[4].y = centerPoint.y + 10.0;
	(*memo.coords)[5] = (*memo.coords)[1];
	(*memo.pends)[1] = 5;
	// hole points:
	(*memo.coords)[6].x = centerPoint.x + 5.0;
	(*memo.coords)[6].y = centerPoint.y + 0.0;
	(*memo.coords)[7].x = centerPoint.x - 5.0;
	(*memo.coords)[7].y = centerPoint.y + 0.0;
	(*memo.coords)[8] = (*memo.coords)[6];
	(*memo.pends)[2] = 8;
	// arcs:
	(*memo.parcs)[0].begIndex = 6;							// makes a circle-shaped hole
	(*memo.parcs)[0].endIndex = 7;
	(*memo.parcs)[0].arcAngle = PI;
	(*memo.parcs)[1].begIndex = 7;
	(*memo.parcs)[1].endIndex = 8;
	(*memo.parcs)[1].arcAngle = PI;
	// roof baseline
	element.roof.u.planeRoof.baseLine.c1.x = (*memo.coords)[1].x;
	element.roof.u.planeRoof.baseLine.c1.y = (*memo.coords)[1].y;
	element.roof.u.planeRoof.baseLine.c2.x = (*memo.coords)[3].x;
	element.roof.u.planeRoof.baseLine.c2.y = (*memo.coords)[3].y;
	// roof angle
	element.roof.u.planeRoof.angle = 5.0 * DEGRAD;
	// create the roof element
	err = ACAPI_Element_Create (&element, &memo);
	if (err != NoError)
		ErrorBeep ("ACAPI_Element_Create (roof)", err);
	return;
}		// Do_CreatePlaneRoof
Sorry, I couldn't test it today. But hope it works, tomorrow I'll check it.
Regards,
Tibor
Hi Tibor,
Thanks very much, really helpful.
Andor
