[SOLVED] Create Stairs using C++ API
Hey there, I wasn't able to find a structure on the C++ API that can represent the stairs that is used on the graphical interface of ArchiCAD. I thought it would be in API_Element, just like walls, windows and the other elements.
Is there any way of creating stairs using C++ API?
Ralph Wessel
A stair is simply an object, so you would use API_ObjectType. The one difference is specifying the correct object tool. Do this by setting the head.variationID to APIVarId_SymbStair.
Ralph Wessel BArch
Central Innovation
Thank you for the answer! =]
