‎2014-11-17
09:38 AM
‎2024-09-24
09:52 AM
Doreena Deng
‎2014-11-17 10:27 PM
typedef struct {
short dialId;
bool isDocked;
bool isDockedTitleHorizontal;
} API_DockStateInfo;
typedef void __ACENV_CALL APIDockStateChangedCallBackProc (short dialId, API_DockStateInfo dockStateInfo);
void ACAPI_Notify_CatchDockStateChanged (short dialId, APIDockStateChangedCallBackProc *callBackProc); void ACAPI_Notify_CatchDockStateChanged (short dialId, APIDockStateChangedCallBackProc *callBackProc)
if (DGGetDialogType (dialId) == DG_DT_PALETTE) {
static GS::HashTable<short, API_DockStateInfo> dockStateInfos;
API_DockStateInfo actDockStateInfo;
actDockStateInfo.dialId = dialId;
GS::Guid paletteGuid;
DGGetPaletteGuid (dialId, &paletteGuid);
actDockStateInfo.isDocked = DGIsPaletteDocked (paletteGuid);
short hFrameSize;
short vFrameSize;
short hClientSize;
short vClientSize;
DGGetDialogSize (ACAPI_GetOwnResModule (), dialId, DG_ORIGFRAME, &hFrameSize, &vFrameSize);
DGGetDialogSize (ACAPI_GetOwnResModule (), dialId, DG_ORIGCLIENT, &hClientSize, &vClientSize);
actDockStateInfo.isDockedTitleHorizontal = (hFrameSize - hClientSize > vFrameSize - vClientSize);
API_DockStateInfo prevDockStateInfo;
if (!dockStateInfos.Get (dialId, &prevDockStateInfo) ||
prevDockStateInfo.isDocked != actDockStateInfo.isDocked ||
prevDockStateInfo.isDockedTitleHorizontal != actDockStateInfo.isDockedTitleHorizontal)
dockStateInfos.Put (dialId, actDockStateInfo);
callBackProc (dialId, actDockStateInfo);
} void __ACENV_CALL DockStateChangedCallBack (short dialId, API_DockStateInfo dockStateInfo)
char buffer[512];
sprintf (buffer, "DockStateChanged: dialId=%d, isDocked=%d, isDockedTitleHorizontal=%d", dialId, dockStateInfo.isDocked, dockStateInfo.isDockedTitleHorizontal);
ACAPI_WriteReport (buffer, true);
// Handle dock state changed event as you want!
// -------------------------------------- With C++ style Palette: -----------------------------------------------------
// Define the following function in the dialog's observer class:
virtual void PanelIdle (const DG::PanelIdleEvent&);
void MyDialogObserver:PanelIdle (const DG::PanelIdleEvent& /*ev*/)
ACAPI_Notify_CatchDockStateChanged (myDialog->GetId (), DockStateChangedCallBack);
// myDialog is a pointer to the dialog
// ---------------------------------------- With C style Palette: -----------------------------------------------------
// In the dialog's callback function:
// at the end of DG_MSG_INIT message handling:
DGEnableMessage (dialID, DG_ALL_ITEMS, DG_MSG_NULL);
break;
case DG_MSG_NULL:
ACAPI_Notify_CatchDockStateChanged (dialID, DockStateChangedCallBack);
break;
